03-08-2014 09:00 AM
Hi all
i have an ni pci 6239 card. i'am using this device to generate waveform with sample timing set to "sample clock" and sample mode set to "continous"
if i do not specify the sampling rate explicitly, what will be my sampling rate.
03-10-2014 10:33 AM - edited 03-10-2014 10:34 AM
The sample rate is a required input when using Sample Clock timing:
You might be using waveform timing, in which case the sample rate would be determined by the dt of your waveform:
Best Regards,
