Multifunction DAQ
data output from daq assiatant
I am using PCI6013 to acquire a voltage signal connected to channel 0. It is configured as N samples in daq assistant. How can I get the average value of that N samples?
Thanks.
(2,035 Views)
Hello
The easiest way is as follows:
Select the express vi "statistics"
wire your data fron DAQ to that vi
open the vi and mark "mean" and any other you like
display result(s)
In the tools palette thera are plenty of statistc calculation vis.
Hope this helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,035 Views)
