ít´s the first time that I hear this, but I´m thinking if you have checked the following:
1. NI-DAQmx base lists your USB board (USB-6008)??
2. Have you be able to tested it (usb-6008) through LabVIEW or other programming language??
3. Have you be able to connect the USB-6008 on other USB port and check it??
4. What kind of task are you configuring (continuous, finite,...) ???. Have you be able to check with other type of tasks??
5. Have you checked if the sampling rate is lower than the maximum rate that you can use??
6. Are you collecting from multiples usb devices?
7. May you test on other PC?
8. Why have you rebooted your PC?
At last but not least, could you explain me the steps that you are making before NI Data Logger doesn´t work fine?? and the graph on NI Data Logger always appears clean?, the timebase (x axis) is moving??
Diego M.
