I'm using MAX to troubleshoot the NI DAQPad 6016 and I have noticed that it sometimes stops acquiring for no reason.
Here is the setup, I'm using a thermocouple as the input source (very low voltage):
AI channel: AI2
Mode: On Demand
Input Config: DIFF
+ is going to AI2
- is going to AI10
100K resistors going from AI2 and AI10 to AI GND to get rid of excess noise.
Using this setup, the daqpad acquires normally for a while and then suddenly stops. No errors, nothing. This happens intermittently and is difficult to predict. To restart it, I simply have to press STOP and START on the Test Panel, or start the counter output or change the state of one of the digital i/o channels.
The same thing happens when I run my software app which uses the 6016. In the app I'm monitoring temperature of a heater block, and as above, the temperature display suddenly locks up.
Do you have any ideas as to what might be happening? Thank you.
Jack Remiasz
Industrial Measurement Systems, Inc.
Message Edited by IMSYSINC on 07-22-2005 04:10 PM
