Multifunction DAQ
analog triggering for noisy digital clock
Help I need somebody!!!
I think for most of you it will be a really simple problem but not for me!! The attached file is my old application where i used to acquire the signal with a digital extern trigger on PFI2 Line, the problem is that for an unknown reason the digital trigger has crosstalk with an another clock (not in this vi), so I decided to use a Lowpass filter, and it works fine I have no more noise but the problem is that my rising slope is now too slow, so I want to use Analog trigger for my application but I can't configure a High Hysteresis analog triggering mode (HighValue:3V;LowValue:0.5V) !!!
How do I configure that ??
Is it possible with the signal clock on the PFI2 line??
(2,260 Views)
Hi still me
I'm working with Labview 6.1 and a PCI-MIO-16E-1
(2,260 Views)
Hallo,
I found two links about this question.
1.
http://zone.ni.com/devzone/conceptd.nsf/webmain/2A03115556FB233386256870005BB522?opendocument
2.
http://zone.ni.com/devzone/conceptd.nsf/webmain/2AF60E522378449286256815005806D3?opendocument
I hope you can get some usefull informations.
Best regards
TN
(2,260 Views)
