Multifunction DAQ
acquiring signals from multiple boards simultaneously
I am trying to acquire signal from my NI PXI cards simultaneously but having some trouble to implement that.
Here is my setup:
Hardware setup:
1) NI PXIe-1071 chassis
2) Card - NI PXI 4461 - 2 I/P and 2 O/P
3) Card - NI PXI 4492 - 8 I/P
Below is the Acquisition code that I have written:
The issue is that when I use the I/P channels on the same card(4461 or 4492) then the code runs fine, but if I use the input channels on both cards simulataneously then I get an error message:
Error -200106 occurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:
Possible reason(s):
Property must have the same value for all channels on this device.
Property: RefClk.Src
I have tried setting the Reference clock to "Onboard clock" but I still get the same error.
What should I do to reslove this issue?
Ritesh
(4,493 Views)
Accepted by topic author LVCoder
Hi Ritesh
Have you tried importing a common ref clocks for the 2 boards? This is not supported by every device, but for the ones you are combining, this should be supported as you can see from page 44 in this document.
WenR
(4,460 Views)
Hi WenR,
I looked at the documents you mentioned and also the synchronization example in NIDaqMx and that solved the issue that I was having.
-Ritesh
(4,422 Views)
LVCoder
I am really glad to know the information was helpful! Thanks for letting us know!
WenR
(4,414 Views)
