Dear all,
I am working with a NI USB-6210 device and the ANSI C API to communicate with it.
I am trying to acquire an image where I have an analog input with the pixel data and a digital trigger, which triggers each line.
So what I am trying to set up is a task which does the following:
For each image line trigger acquire n Samples and write them to a buffer or call a callback function.
My first approach was to start a task for each line, but this way I am loosing lines, because the initialization of the tasks takes too long.
Secondly, I was trying to record the whole image with a task which has an analog and digital channel, so that I can look for the trigger pulse and read the analog values from the corresponding index in the buffer. This apparently is not support by my USB device.
So my questions are:
Does anyone know a solution which works with my USB-6210 device or how I can setup a task which acquires a specific number of samples every trigger pulse?
If this is for sure not possible with the USB-6210 device, which device would support the sampling of digital input, so that I can implement my second approach?
Many thanks in advance for any hint.
Best regards
Martin
