NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Gredal
Accepted Solution
XP Mode will not recognize my PCI 6023E Card
I bought a new Win 7 with a legacy PCI slot to run an OLD NI PCI 6023E card that I have used for years.  I downloaded the NI legacy drviers (7.4) but it does not see the card.  When I look in Win 7 the card is there but I can't run the legacy drivers at 64bit and with my legacy software (C++).   I connected a NI USB 6008 card and was able to open the card in XP mode... any ideas?
Member
bstreiff
Re: XP Mode will not recognize my PCI 6023E Card
Unfortunately, XP mode does not work with PCI/PCIe devices, only USB ones. Most (all?) virtualization programs will have this limitation.
As you probably expected, the general recommendation is to migrate to the NI-DAQmx APIs for your application if you want support on Windows 7.
If that's not possible, then there is a knowledgebase article about a beta Traditional NI-DAQ (Legacy) for Windows Vista and 7 which you might be interested in. At a minimum, it will require you to use a 32-bit installation of Windows 7, not a 64-bit one.
bstreiff
NI R&D
Member
Gredal
Thanks for your prompt response.  I have a C++ software program that is quite sophisticated and would like to continue to use it...would it access an NI mx card in the same way as the PCI 6023E or would I have to have the Program rewritten...ie is the read AI1, or write to DO1 the same for both cards?
Member
bstreiff
NI-DAQmx supports your PCI-6023E, so there's no need for a new 'NI mx card'. However, the programming API between the NI-DAQmx driver and Traditional NI-DAQ is considerably different; unfortunately, you'll have to modify your program.
The following articles might be useful:
bstreiff
NI R&D
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
