08-24-2015 06:34 PM
Hello, I just "upgraded" to Windows 10 and installed everything required for myDAQ and Windows isn't recognizing the driver. Has anyone else had this issue and found a fix?
I installed the most recent drivers for DAQmx (15.0.1) and Elvis (15.0) without any luck. I attached the errors from both NI MAX and Device Manager
Thank you for your help!
Solved! Go to Solution.
08-25-2015 10:37 AM
Hi jtkrenz,
Unfortunately, Windows 10 is not yet supported by DAQmx and Elvismx. This can be seen under the OS Support in their respective Readme:
1. NI-DAQmx 15.0.1 Readme
http://download.ni.com/support/softlib//multifunction_daq/nidaqmx/15.0.1/readme.html
2. NI ELVISmx 15.0 Readme
http://download.ni.com/support/softlib//multifunction_daq/nielvis/15.0/readme.html
Thanks!
08-25-2015 11:04 AM
08-25-2015 11:43 AM
Hey jtkrenz,
Would you be able to provide more information about your system setup, upgrade process...
Any information you can provide would be greately appreciated!
~ Sandra
08-25-2015 03:39 PM - edited 08-25-2015 03:39 PM
Hello Sandra, to answer your questions.
1) My new laptop is running an I7 Intel CPU, NVIDIA GeForce GTX 970M and has 24 GB of ram (way more than my previous computer that ran everything fine). I do have multiple 3.0 USB ports and I have tried plugging the myDAQ into all of them. The computer recognizes the myDAQ and says that there aren't any drivers installed for it.
2) I upgraded from a clean install of 8.1 Professional (64-bit).
3) I did not have NI software installed before the upgrade.
4) LabView, DAQmx and ELVISmq were all installed after the upgrade.
5) I installed a clean copy of Windows 8.1 and upgraded to Windows 10 (also 64-bit). The Windows 10 installation seemed very similar to any other OS, except that it optomized current drivers and programs during the install. This shouldn't be a factor since nothing was installed until after the installation. After the upgrade, I installed the previous versions of DAQmx and ELVISmx (14.x, I believe), but I was having the same issue (driver not recognized) so when NI release the new drivers I tried installing those as well.
6) I have restarted numerous times since each install. Whenever a program or driver doesn't work right after installation, my first troubleshooting technique is to restart.
Hopefully that helps expand upon my issues. Thank you for your help!
-Josh
