First of all, I just upgraded from NI-DAQ 7.1 to NI-DAQ 7.2. The following problem appeared just after this upgrade, without any change to the VI's.
I am runnning VI's that can control the state of a relay (connected/disconnected) using a digital line. For some reason, whenever I close Labview (not just the VI), that digital line is set to high, causing the relay to do an unwanted connection. Normally, the digital line should stay to the state it was when leaving LavView (it worked correctly before the upgrade of NI-DAQ).
For your information, I am running Labview 6.1 under Windows XP and my data acquisition device is a PCI-6110.
Any idea on how to solve this? Thanks in advance.
