Hello Alfanso,
Do you get any type of error when you try running this example at 200 kS/s? Or can you just see from the Data and Waveform Graph indicators that only 700 samples were acquired? Also, according to the Waveform Graph's timestamps, how much time has elapsed in a single scan?
To troubleshoot this and give yourself some idea of what might be going wrong, it is a good idea to place indicators on the outputs of the Traditional DAQ VIs. Some of these include Actual Scan Rate on AI Start, Scan Backlog and Number Read on AI Read.
Are you trying to acquire all of your data off of a single channel? Is the data being read being generated continuously? What version of LabVIEW and NI-DAQ are you using?
Best,
Jared A
