Other than bug fixes about 90% of 7.3 is support for new or existing products. We did add multi-measurment support which allows you to specify heterogeneous tasks in the assistant. For instance voltage and resistance measurments, but not analog output and counter. This used to only be possible exclusively through the API, but is now avaialable through the assistant.
Stuart G
