Multifunction DAQ
What s the concept behind DAQ AO property Output Buffer size,Where is it created
I would want to understand the concept behind DAQ AO property "Output Buffer Size". Where is this buffer created ? I understand DAQ card has only on-board FIFO memory. Where does this output buffer come from ? Also is there a specific size limit for this buffer ? If so where do I find the maximum size from ? I went through the DAQ card specifications document but could not find anything relevant. Also are there any factors which affect this size. Like if we have more AO channels enabled, will be size per channel be less ? If we are using AI along with AO whether this Output Buffer size changes ?
Message 1 of 1
(3,552 Views)
