NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
gumus
What is the maximum power on NI usb 6210 ?
Hi all,
I have to measure 400VAC i need therefore a transformator,which makes the voltage lower than -+10V.i need to know maximum power and maximum current for the ni usb 6210,so that i can order the suitable transformator.
Can anybody help me for it ?
thank you!
Knight of NI
Dennis_Knutson
Re: What is the maximum power on NI usb 6210 ?
Main product page with links to the manual and specs.
Member
gumus
thank you!
Input current during overvoltage condition -+20mA max/AI pin,so that means maximum current for my DAQ device right?
±20 mA max/AI pin
Member
Stephan_D
Hi Gumus,
the Input current during overvoltage condition doesn't contain the information, which you are serching for. If you look in the Datasheet, you will find the following Information:
If the input voltage is approximately 10V, than you can calculate the input current I=U/R= 10V / 10G Ohm = 1nA. Like you see, you don't have to calculate the input current or input power of the NI USB-6210, because the input resistance is so big.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
