Hello Mark
I guess you are using Windows, so there are too many variables ( processor speed, other applications, etc) to state a buffer size.
As a rule of thumb, do next steps:
1. define a big buffer for testing ( 200000 samples).
2. run your program an keep memory of bigger backlog size.
3. run differenten applications ( Word, acrobat, screen saver etc) an let the pc 2 or 3 days working.
4. Note the maximun backlog an set the real one at about 4 times this amount.
You can be quite sure your application will run fine in that PC.
I did this procedure and the Adquisition aplications run during months whithout problems.
Hope it helps.
"Qod natura non dat, Salmantica non praestat"
