Hi again tritone
By default, waveforms are DBL data format ( see Application note 154). One way to cut size down and keep using waveform data type is:
1- scale waveform for 16 bits.
2 extract Y ( dbl)
3 conver Y to I16
3 insert into waveform
The new waveform will be I16 data (1/4 of DBL)and you will keep all waveform attibutes.
It should decrease file size
Hope this helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
