The actual input ranges of the DAQ board are fixed. I don't know the specifics of your board but the ranges might be +/-10, +/-5, +/-1, 0-1, 0-5, 0-10, etc. When you specify a minimum and maximum value, NI-DAQ uses that information to select the most appropriate range. So, in your case, if the board supports 0-2 volts, that is the range that will be selected and that's the value to use for resolution. If the DAQ board does not have a 0-2 range and only has a 0-5 range, then you need to use this number.
