Multifunction DAQ
[VB to VB.net] what is the VB.net equivalent of 'NIDAQmxCAPI.DAQmx.DAQmxGetErrorString'?
Hi all,
I am working on conversion between VB and VB.net.
Instead of refering to 'NIDAQmxCAPI.DAQmx' which is not valid in VB.net, I am now refering to 'NationalInstruments.DAQmx'
For most of the functions such as creating a task and creating channels, I can find VB.net equivalent.  However, I cannot find the equivalent of 'NIDAQmxCAPI.DAQmx.DAQmxGetErrorString'.
Could anyone help me on this?
Attached is the code:
If (ErrorCode < 0) Then
' Find out the error message length.
'UPGRADE_ISSUE: COM expression not supported: Module methods of COM objects. Click for more: 'ms-help://MS.VSCC.v90/dv_commoner/local/redirect.htm?keyword="5D48BAC6-2CD4-45AD-B1CC-8E4A241CDB58"'
bufferSize = NIDAQmxCAPI.DAQmx.DAQmxGetErrorString(ErrorCode, CStr(0), 0)
' Allocate enough space in the string.
errorString = New String(Chr(0), bufferSize)
' Get the actual error message.
Status = NIDAQmxCAPI.DAQmx.DAQmxGetErrorString(ErrorCode, errorString, bufferSize)
' Trim it to the actual length, and display the message
errorString = Left(errorString, InStr(errorString, Chr(0)))
End If
And the error message is :
'DAQmx' is not a member of 'NIDAQmxCAPI'.
Thanks a ton!
(2,945 Views)
Was there a solution for this problem as I am experiencing the same issues currently.
(123 Views)
