Multifunction DAQ
VB.NET problem with ni 6008
I've made a visual basic proyect based on some C# code found in the forum. It is just a test proyect to start working with ni 6008.
I'm using a times to get the AI0 value and a checkbox to light a led.
There is something brong with it because it doesn't works always.
(2,672 Views)
Hello haizetara,
I've actually found a couple of other threads on how to use the USB 6008 with VB.NET here and here.
I would take a look at these (there is some example code posted in one of them) and see if you are still getting the same behavior.
Eric
DE For Life!
(2,617 Views)
