I have an NU USB-6363 X Series Multifunction DAQ.
I need to know if this situation is hypothetically possible so that I can use that fact to build a part of a program for saving data from a pressure sensor.
Say I have a physical pushbutton wired into a Digital In port on my DAQ, and I have a DAQ Assistant express VI, which is in a while loop, reading that Digital In port, and is set to 1 Sample (on demand).
Assuming that the DAQ Assistant is only capable of generating 1 High or Low value per loop iteration (since it's set to 1 Sample), couldn't you use the push button in this manner to control a Case Structure through the DAQ Assistant?
Thank you
