04-19-2012 10:38 AM
I am trying make a communication between Matlab and my NI-USB6221 card.
Here is my Matlab code :
loadlibrary('nicaiu.dll','nidaqmx.h','alias','myni')
taskh1=uint8(1);
[a,b,taskh1] = calllib('myni','DAQmxCreateTask','master',taskh1)
I precise that the files 'nicaiu.dll' and 'nidaqmx.h' are in the Matlab workspace (so I don't have to use addpath). And I don't have Data Acquisition Toolbox.
And this is what I get :
Warning: Warnings messages were produced while parsing. Check the
functions you
intend to use for correctness. Warning text can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 381
In dll_nidacmx at 6
??? Error using ==> loadlibrary at 461
There was an error loading the library "C:\Documents and
Settings\uidt1982\Desktop\CARTE_NI\nicaiu.dll"
La procédure spécifiée est introuvable.
Error in ==> dll_nidacmx at 6
loadlibrary nicaiu.dll nidaqmx.h
Caused by:
Error using ==> loaddefinedlibrary
For the ones who doesn't speak french at all, the phrase in bold means : "the specified procedure cannot be found"
I don't understand this error and I am really stuck...
Some help would be welcome.
04-20-2012 03:21 AM
OK, it works today...
In fact, it seems that my lib file was not recognized
07-17-2012 04:40 AM
Hello, I want to generate an executable program using Matlab.
This executable will use DAQmx functions to acquire analog data for instance.
There is no problem with creating the executable. I build including "nicaiu.dll", "NIDAQmx.h", "NIDAQmx.lib", and all others functions needed.
But, when I want to run the executable, here is the response from Matlab :
"C:\Users\...\Windows\System32\nicaiu.dll"
Undefined function or variable 'myni_proto'.
How can I fix it ??
07-19-2012 08:57 AM
Nobody ??
08-22-2012 06:01 AM
I am having the same problem as you except I am not looking to create an excecutable progrma in matlab. When I try to run the folowing piece of code:
I get loads of errors such as :
Warning: Warnings messages were produced while parsing. Check the functions you intend to use for correctness. Warning text can be
viewed using:
> In loadlibrary at 344
Warning: The data type 'error' used by function DAQmxGetTaskAttribute does not exist.
> In loadlibrary at 403
Warning: The data type 'FcnPtr' used by function DAQmxRegisterEveryNSamplesEvent does not exist.
Warning: The data type 'FcnPtr' used by function DAQmxRegisterDoneEvent does not exist.
Warning: The data type 'FcnPtr' used by function DAQmxRegisterSignalEvent does not exist.
Warning: The data type 'error' used by function DAQmxGetChanAttribute does not exist.......
I'm not sure what I'm doing wrong I guess there is a fundamental problem with the nicaiu.dll? It's very unusual because yesterday I used the same line of code and got a different error which was the one you had in your first post. How did you get matlab to recognise your library?
thanks,
Alan
08-06-2015 02:47 AM
64 bit Matlab (2015a or 212b) crashes every time I try to create a task with NI-DAQmx Base 14.0. Surprisingly, 32 bit Matlab (2010a) seems to work fine. Any ideas how to solve the problem with 64 bit Matlab?
Here is a simple way to replicate my error. Load nidaqmxbase from Ni-DAQmx Base 14.0 library. Then call DAQmxBaseCreateTask.
Example code:
loadlibrary('/Library/Frameworks/nidaqmxbase.framework/Versions/14/nidaqmxbase', ...
'/Applications/National Instruments/NI-DAQmx Base/includes/NIDAQmxBase.h', ...
'alias', 'nidaqbase');
task0 = libpointer('uint32PtrPtr',0);
calllib('nidaqbase','DAQmxBaseCreateTask','',task0);
Here is Matlab's crash dump:
Configuration:
Crash Decoding : Disabled
Crash Mode : continue (default)
Current Graphics Driver: Unknown hardware
Current Visual : Quartz
Default Encoding : ISO-8859-1
Host Name : new-host-2.home
MATLAB Architecture : maci64
MATLAB Root : /Applications/MATLAB8.5.app
MATLAB Version : 8.5.0.197613 (R2015a)
OpenGL : hardware
Operating System : Darwin 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
Processor ID : x86 Family 6 Model 70 Stepping 1, GenuineIntel
Virtual Machine : Java 1.7.0_60-b19 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode
Window System : Quartz
Fault Count: 1
Abnormal termination:
std::terminate()
Register State (captured):
RAX = 0000000054b0786c RBX = 0000000122255a50
RCX = 00007fcb1fa180d0 RDX = 0000000054b07820
RSP = 0000000122255300 RBP = 0000000122255620
RSI = 00007fcb1dce1b00 RDI = 0000000132265000
R8 = 00007fcb1dce7910 R9 = 0000000054a204e6
R10 = 00000001322bb000 R11 = 00007fcb240253e0
R12 = 0000000000000000 R13 = 0000000000000000
R14 = 00000001136bd420 R15 = 0000000000000000
RIP = 000000010ffad8ab RFL = 00007fcb2406a370
CS = 0000000054b07db0 FS = 0000000132687000 GS = 00007fcb2406a4a0
Stack Trace (captured):
[ 0] 0x000000010ffa8964 /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00031076 _ZN2fl4diag15stacktrace_base7captureERKNS0_14thread_contextEm+00000052
[ 1] 0x000000010ffac02b /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00045099 _ZN2fl4test17terminate_handledEv+00000763
[ 2] 0x000000010ffabac7 /Applications/MATLAB8.5.app/bin/maci64/libmwfl.dylib+00043719 _ZN2fl4diag13terminate_logEPKcPK17__darwin_ucontext+00000119
[ 3] 0x000000010fa17f9b /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00380827 _Z32mnRunPathDependentInitializationv+00002875
[ 4] 0x000000010fa18217 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00381463 _Z32mnRunPathDependentInitializationv+00003511
[ 5] 0x000000010fa17908 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00379144 _Z32mnRunPathDependentInitializationv+00001192
[ 6] 0x000000010fa17384 /Applications/MATLAB8.5.app/bin/maci64/libmwmcr.dylib+00377732 _Z22mnInstallCrashHandlersv+00000420
[ 7] 0x00000001134b41d1 /usr/lib/libc++abi.dylib+00147921 _ZSt11__terminatePFvvE+00000008
[ 8] 0x00000001134b3c5b /usr/lib/libc++abi.dylib+00146523 _ZN10__cxxabiv1L22exception_cleanup_funcE19_Unwind_Reason_CodeP17_Unwind_Exception+00000000
[ 9] 0x00000001132c8fa1 /usr/lib/libobjc.A.dylib+00057249 _ZL26_objc_exception_destructorPv+00000000
[ 10] 0x000000011204a12d /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+01380653 -[NSObject(NSObject) doesNotRecognizeSelector:]+00000205
[ 11] 0x0000000111fa5272 /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+00705138 ___forwarding___+00001010
[ 12] 0x0000000111fa4df8 /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation+00703992 _CF_forwarding_prep_0+00000120
[ 13] 0x000000013b6ff6af /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13133487 _ZN19MainLoop_MacCocoaUIC2Ev+00000095
[ 14] 0x000000013b6ff73c /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13133628 _ZN19MainLoop_MacCocoaUI4InstEv+00000060
[ 15] 0x000000013b7e2dea /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14065130 WSendEvent+00000250
[ 16] 0x000000013b7e3f8f /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14069647 WCreateEx+00000543
[ 17] 0x000000013b7e420e /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14070286 _ZN8WMgrCore10InitializeEv+00000254
[ 18] 0x000000013b793790 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+13739920 _Z12InitManagersiPKPKcPiP14MGAppInterfaceP16MGUIAppInterfaceS0_+00000512
[ 19] 0x000000013aabbb53 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00273235 _Z10MGMainInitiPKPKcPb+00000179
[ 20] 0x000000013aabbf84 /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00274308 _Z6MGMainiPKPKc+00000132
[ 21] 0x000000013aabcaed /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+00277229 _Z11SysUIThreadPv+00000013
[ 22] 0x000000013b854e9e /Library/Frameworks/LabVIEW 14.0 Runtime.framework/LabVIEW 14.0 Runtime+14532254 _Z15ThreadCoverProcPv+00000094
[ 23] 0x000000011385d899 /usr/lib/system/libsystem_pthread.dylib+00006297 _pthread_body+00000138
[ 24] 0x000000011385d72a /usr/lib/system/libsystem_pthread.dylib+00005930 _pthread_struct_init+00000000
[ 25] 0x0000000113861fc9 /usr/lib/system/libsystem_pthread.dylib+00024521 thread_start+00000013
