Multifunction DAQ
Under VI
HI. For more easy, I join you my VI so that you can manipulate.
I need to recover temperature and tension values at the same time. So I create 3 VI who I add in a big one. All VI works corretly, but when I gather it in the big one, they don't turn at the same time, and that brake my VI.
First VI going to create a graph, where I can see all of my thermocouples. I set a sampling frequency just for him.
Also, I want to recover some températues. Tipically, I see each secondes the températures in my graph, but i want to record every 5 secondes. So i set a new sampling frequency. It's the role of my second VI.
The last displays and records tension values, with the time, in a EXCEL file. I have the same sampling frequency for displaying and recover values.
So now, I just want my VI turns to infinity
Thank you for you answer.
Message 1 of 8
(3,350 Views)
1. You did not include the subVIs, so we cannot troubleshoot.
2. What hardware are you using?  You may be able to combine the temperature and tension readings into a single task.
GCentral
Message 2 of 8
(3,332 Views)
I use :
-Ni 9214 16-CH Isothermal TC, 24-bit C ( thermocouples )
-NI 9205 16 bits, 250kech/s, +/- 10V, 16 voies differential
Message 3 of 8
(3,322 Views)
Accepted by topic author Jeremie.D
Seeing that the sample rates are all the same and with the assumption both modules are in the same cDAQ chassis, just combine all of your readings into a single task.  You can then use a Producer/Consumer setup to send data to parallel loops for the processing and saving of the data.
GCentral
Message 4 of 8
(3,318 Views)
I have two sampling frequency :
- One to have the temperatures in a graph, and for the measurements of voltages
- Another to save temperature values in an EXCEL array.
What is the PRODUCER / CONSUMER configuration?
Message 5 of 8
(3,312 Views)
Your code currently has both running at 1 sample per second per the inputs to the DAQmx Timing.vi
Follow the link I provided
GCentral
Message 6 of 8
(3,310 Views)
It's just that the commands did not save, but I still have 2 separate sampling frequencies. Do I have to create 2 tasks?
Thank you
Message 7 of 8
(3,307 Views)
OK, I think I understand thank you
Message 8 of 8
(3,291 Views)
