08-12-2015 10:18 PM
I'm trying to install a PCI 6034E card (only option available to me) on a Windows 7 (64 bit) PC with Labview 8.6. A force transducer I need to use requires DAQmx 9.5.1 to be installed, however when I try to setup DAQmx 9.5.1, I get the following error -
"LabVIEW Version Unsupported by NI-DAQmx
This installer has detected that you have a version of LabVIEW that is not supported by NI-DAQmx. Please refer to the feature tree in this installer to see which versions of LabVIEW are supported by NI-DAQmx in this release. This installer will remove NI-DAQmx LabVIEW support (if present) from any unsupported versions of LabVIEW."
I have confirmed version compatibiliy here - http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248. I downloaded the 9.5.1 driver online (not from a CD).
I would really appreciate some guidance. Thank you!
08-13-2015 10:32 AM
Hi needhalp
Could you tell me if you had any other DAQmx in your computer before the 9.5.1 version
