07-09-2015 08:40 AM
m.caron,
Thank you for your feedback, we really appreciate it! We will take this into consideration. I'm glad you were able to still find the resources to solve your issue as well 😃
Have a good day!
08-18-2015 05:05 PM
I'm getting this same error message with the USB-TC01. I'm using LabVIEW 2010 with DAQmx 9.9 and I just followed the instruction to update the TC01 firmware to version 1.2. Do I need to downgrade the firmware or upgrade LabVIEW?
Gary
08-19-2015 08:18 AM
Update DAQmx to the latest and get the tc01 update tool!
08-19-2015 11:46 AM
LabVIEW 2010 doesn't support the latest DAQmx version, unless I'm mistaken.
08-19-2015 12:04 PM - edited 08-19-2015 12:05 PM
You are correct LabVIEW 2010 only supports up to DAQmx 9.9 (http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248). Do you have a newer version of LabVIEW to try?
08-19-2015 12:56 PM
I do not, but I could see about getting a newer version. Is this the only solution?
08-20-2015 10:43 AM
It would be worthwhile to troubleshoot it on a newer version, but before you do that I would try doing a reinstall of your drivers and the firmware.
08-20-2015 11:01 AM - edited 08-20-2015 11:02 AM
If the hardware revision of the USB-TC01 is D (PN: 195564D-01L) or later, it is supported by DAQmx versions 14.5 or later, only. If the device is a revision C or earlier, you should be able to downgrade the firmware for compatibility with earlier versions of the driver.
09-09-2015 09:34 AM
I am getting the same error. I just purchased a USB-TC01 and the firmware updater is showing that the current firmware on the device is the same as what the software wants to put on which is 1.1.0f1 I am running Labview 14.0f1 with Max 14.0.0f0.
Any suggestions would be appreciated.
09-10-2015 04:07 PM
Try this update utility http://www.ni.com/download/ni-instantdaq-firmware-update-utility-1.2/5284/en/
