11-18-2015 08:41 AM
Hi all,
I'm trying to use the USB-6501 to drive a stepper motor. I need a 0-5 V open collector type signal. I've attached my DAQmx Base and VI screenshots below. Is there a way to test whether or not I got this right? I can't plug in the motor drive to test at my desk, it takes a very high voltage. Any help would be greatly appreciated. Thanks.
11-19-2015 03:55 PM
Hello sullivnc,
To test your task you could create a Digital Read task using your USB-6501 and read with it the value you are writing.
Also if you have a Voltmeter you could measure the value you get at the output.
I hope this helps.
