09-19-2011 06:52 PM
I installed DAWmx 9.4 but still don't see that particular property. I'm looking in a daqmx channel property node under AI - General Properties - Advanced - Data transfer and Memory. Is that the wrong location? Wait, do I have to be developing with Windows 7 to see that property?? I'm developing w XP but deploying to a Win 7 computer. Thanks. This is with USB 6008.
Matt
09-20-2011 11:28 AM
This is where you should see it
Hopefully that helps.
Jacob K
09-20-2011 12:24 PM
Tried with both OEM and regular 6008 and 6009 and I still don't see that property. I'm developing on a windows XP machine, LV 2011, DAQmx 9.4.
Some more information on the problem:
I am deploying on a Fujitsu tablet Q550. Windows 7 Labview 2011. I realize this may be borderline in terms of computing power however, I have run for several hours sampling at 50hz on 4 channels without a problem. It's only if I exit and restart the program that the board locks up. It won't respond even in MAX (tried resetting) until I unplug it and plug it back in.
09-21-2011 05:50 PM
Hey mattvx,
If you installed DAQmx 9.4, then the that property should be there. If it's not showing up, then something may have not installed correctly, so try installing DAQmx 9.4 again to see if that property appears.
Hope this works for you,
09-21-2011 05:56 PM
Are you filtering your property node by some subset of hardware that doesn't include the property in question?
You can right-click the property node and choose "Select Filter..." to configure this.
Best Regards,
09-22-2011 04:15 PM
Ohh I had "show attributes for configured devices" checked so even with the device (6008) plugged in it wasn't showing up. When I choose "show all" everything is there. I had never used the filter option before; is it new? Thanks for the help. I'll give the usbxferreqcount a try now and see if it works.
09-22-2011 04:31 PM
Good to know--that attribute should show up though if the 6008 is plugged in--I can file a corrective action request on the behavior.
Best Regards,
09-27-2011 01:52 PM
Update - Tested the same software on an HP Slate tablet and a Lenovo all-in-one and I don't have any problem restarting the software. These machines are also both windows 7 (HP-32bit; Lenovo 64bit).
On the Fujitsu everything works when USBxferreqcount = 1! Thanks for the help.
-Matt
11-01-2013 06:58 PM
I have read 2-3 pages of this section. I am giving the exact answer for this problem.
First of all, I am using USB-6009 daq board for data acquisition using DELL computer. I have read most of the blog related changing computer for solution of that error.
The solution of this problem is user must build .exe file using labview. When you build .exe file, that error is eliminated. This error is not stemming from buffer overflow or something. DEscription for this error is not useful. This error comes from the protocol problem between computer and daq board.
