11-05-2014 06:15 AM
I asume:
- you need to do the testing because there is a requirement.
- you need something like 1-2 ms timing resolution to make brownout/ power down tests on your products.
- with USB 6008 software timing jitter, relay timing jitter and bouncing..... how do want to repeat a test (get the same result under the same conditions) if your switching condition is not stable?
you can have it : good, cheap and fast .... pick two 😉
One hint for a solution: have a look into the standards on how to perform such test.
11-05-2014 10:22 AM
Its not meant to be used for compliance testing. Its meant to be used for prototyping tests. But its a long story.
