Multifunction DAQ
USB-6008 DAQ not detected in LabVIEW
Hello Fatsat,
My apologies for the misunderstanding.
I thought the 8.5 you mentioned only refered to the DAQmx version.
The reason I thought this was because LabVIEW 8.5 predates the release of Windows 7, hence it does not officially support Windows 7.
Please uninstall the DAQmx 9.8 driver and install version 9.3:
http://www.ni.com/download/ni-daqmx-9.3/2337/en/
This is the latest NI-DAQmx version that supports 8.5 and also support Windows 7.
PS: Sorry I didn't see this more clearly. I have been partially sick the last days and this probably has affected my focus.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 14
(2,167 Views)
Accepted by topic author Fatsat
Hi Fatsat,
The latest version of DAQmx that suppiorts LabVIEW 8.5 is NI-DAQmx 9.3. You can download the installer here:
You should uninstall version 9.8 and after that install 9.3. The installer will detect that you have LV 8.5 installed and install the support for it.
Let me know if there are any issues after that.
Rik Prins, CLA, CLED
Software Development Engineer
Message 12 of 14
(2,166 Views)
Download and installed it and everything works just fine!
Thanks everyone for helping me!
Message 13 of 14
(2,145 Views)
It indeed worked!
Thank you for your time and get well soon!
Message 14 of 14
(2,144 Views)
