You could try using an Intensity Graph. This has a ColorMapArray that you can use to assign certain colors to certain values, and every value in between gets assigned a gradient automatically. All you would have to do is create your Z array, which is a 2d array mapping of the graph control. To use this, call the function PlotIntensity on a waveform graph control. Hope this helps!
Jeremy L.
