Multifunction DAQ
Time since DAQ Power On?
Since the calibration of a device is sensitive to temperature and given that the user manual recommends that a device is allowed to be powered for a period of time before using it, is there a way to read back from the device the time since it was powered on?
(3,715 Views)
If your device has an internal temperature sensor you can read it.
Property : DAQmx calibration info _ devTemp
Power on time .... I have not seen ... but your OS should be aware of it. Even USB devices migth be logged somewhere...
Greetings from Germany
Henrik
LV since v3.1
(3,713 Views)
The temperaure reading won't help too much unless I spend a period of time measuring it to see if it is changing, this could be several minutes.  However this may be a solution if I have a temperature sensor and the operator will at least have some time to go and make a cup of tea!
The OS solution assumes that the PC was on when the device was powered and plugged in (I have a USB device), although I suppose as long as the OS has seen it continuously for say 15 minutes then this could work.  Not sure if it is possible though.
Maybe this would be a useful addition to DAQ products.
(3,702 Views)
