I use the PXI-6031E card to read voltage, but the value is not correct, if the real voltage less then 4V, it will get the value 6V great than the real voltage, if the voltage is great then 4V, it will display 10V. I use the multi-meter to measuer the voltage, it can get correct value, so I think may be the driver software has some problem.
