Multifunction DAQ
The program can't start because nidaq32.dll is missing from your computer. Try reinstalling the program to fix this problem. Notes: DAQ is not installed.
Notes: DAQ is not installed. M&A Explorer has been Refreshing for the last half hour.
(5,544 Views)
I guess there is no Traditional DAQ installed on your computer and the software which you are trying to run/load is using it. On Windows 7 you need Traditional DAQ 7.5. Windows XP works with older versions like Traditional DAQ 7.4.4
(5,519 Views)
You can read about this error here, but the other poster is correct. You need Traditional DAQ installed.
http://digital.ni.com/public.nsf/allkb/F7F09E0377369C7586257150005D00F3
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
(5,506 Views)
Thanks for your responses. I thought this error had something to do with the fact that I hadn't installed the I/O card yet.
This computer controls a piece of test equipment. The application software is supplied by the equip. mfg. who specifically stated to install NI driver, then their application software and finally the card. I would of thought the card would of been installed first then the driver. I've not worked much with I/O cards and their drivers before.
The error code went away and I was able to run the application software.
(5,488 Views)
