I am new to NI boards. I have to use Testpoint for a workstation.
I have to sync up the output of the card to the input channel.
I have a PCI 6052E board and an SBC terminal block. In this box
I have Two OUTPUT channels and one channel coming back in.
I've been told that using Testpoint alone does not do the trick.
Can I use a dll file to send the right set of instructions? I found this on the web:
Can I synchronize a one-channel analog input data acquisition with
a one-channel analog output waveform generation on my PCI-MIO E Series
board?
Yes. One way to accomplish this is to use the waveform generation timing
pulses to control the analog input data acquisition. To do this, follow
steps 1 through 4 below, in addition to the usual steps for data
acquisition
and waveform generation configuration.
1. Enable the PFI5 line for output, as follows:
* If you are using NI-DAQ, call Select_Signal(deviceNumber,
ND_PFI_5, ND_OUT_UPDATE, ND_HIGH_TO_LOW).
* If you are using LabVIEW, invoke Route Signal VI with signal
name set to PFI5 and signal source set to AO Update.
2. Set up data acquisition timing so that the timing signal for A/D
conversion comes from PFI5, as follows:
ND_IN_CONVERT, ND_PFI_5, ND_HIGH_TO_LOW).
* If you are using LabVIEW, invoke AI Clock Config VI with
clock source code set to PFI pin, high to low, and clock
source string set to 5.
3. Initiate analog input data acquisition, which will start only when
the analog output waveform generation starts.
4. Initiate analog output waveform generation.
