Reply
TO uninstall all NI products i need MSI BLAST.EXE
Go to Solution
Highlighted
I WANT TO REINSTALL MY SYSTEM TO CLEAN UP ALL NI PRODUCTS AND HIDDEN FILES I NEED MSIBLAST.EXE
Message 1 of 9 (37,929 Views)
Re: TO uninstall all NI products i need MSI BLAST.EXE
[ Edited ]
Here ya go...
George
Message 2 of 9 (37,904 Views)
I went to add/remove, clicked on the NI option, and selected everything, and all that was there got removed, and i restarted my computer (XP).
I went to my program  files, and the NI directory along will many folders are still there (36M total).  I tried to run MSI blast, but no NI  are listed, so I cannot run anything.  I tried to manually delete the folders, and I got an error saying I cannot delete (....dll)
Any solutions? I basically just want to fully remove NI from my computer so that I can install labview 8.6 only.
Message 3 of 9 (33,561 Views)
I am having the same problems. I found this .pdf however, that can give some clues to some more action needed, among other things the deletion of values from the registry. See the following link for the accompanying MSIBlast pdf. http://forums.ni.com/ni/attachments/ni/250/34391/2/MSI%20Blast.pdf
Message 4 of 9 (33,525 Views)
Disclaimer:
Using the MSI Blast tool is not encouraged as it can not only uninstall all NI products, but may also result in lost data. Please speak with an NI engineer before running the MSI Blast executable.
Message 5 of 9 (23,550 Views)
Here's an updated related post using the NI-shipped NIUninstaller.
Copyright © 2004-2017 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 2.5 License.
Message 6 of 9 (21,848 Views)
Hi all ;
Also I need MSIBLAST.exe could you send it to me ?
Message 7 of 9 (18,509 Views)
Can I have a copy of msiblast?  I need one as well
Message 8 of 9 (13,197 Views)
Accepted by Matt_McLaughlin (Community Team)
‎08-27-2015 06:09 PM
Hi all,
This thread has come back to life a few times. To clarify, MSI Blast is an unofficial tool that can be used to uninstall NI Software. The vast majority of uninstallations are successful using the recommended process for uninstalling National Instruments software. MSI Blast is very rarely used as a troubleshooting step in cases where software fails to uninstall, and we encourage you to contact NI Support if you are experiencing difficulty with the uninstallation process.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 9 of 9 (12,111 Views)
