Hi, I am using a PCI-6221 multifunction DAQ board with Windows XP and Labview 7.1.
Need: I am doing photon counting luminescence measurements following optical excitation. I need to output separate but synchronized digital signals to control an excitation light, PMT gate, and data acquisition device. I need the timing to be accurate down to ~tens of microseconds range. I need to output a digital pulse that I can vary the duration of (from microseconds to seconds) to the excitation light. After that pulse I need to send digital high to the PMT gate and a trigger pulse to the data acquisition device.
SOLN: I have been trying to use the two counters on the 6221 board to generate two digital pulses but I am having trouble getting them synchronized accurately. I can make my system work with two controllable digital pulses, three would be nice but I only have two counters on this board.
Another option I have tried without success is to output a digital waveform that I would input from a file. Any help would be greatly appreciated.
Also, in the future I will need to synchronize these pulses with a analog output waveform.
Brian
