NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Bobino
Synchronized analog input output
I am simply trying to synchronize an analog output and an analog input for a finite number of sample. I am using a DAQ USB 6211 with NI-DAQmx base on a linux machine. I have Labview 10. You can see the block diagram below ans also my VI.
For now, the programs run but does not output anything. I am using a digital oscilloscope to verify and I would see something if it was there. If I remove the "Start Trigger" icon, the program output the ramp as it should. As for the input, it always seems to be working properly.
I would appreciate any help. I am sorry if this is trivial. I tried looking at examples online but always fell on examples using NI-DAQmx and was never able to do the translation.
Thank You very much
Member
margasan
Re: Synchronized analog input output
Hello Bobino
Basically what you need to share between the two tasks is the Start Trigger and the Sample clock, however you can watch this video, this is for 2 devices but can be applied to just one. All the VI´s needed exist in the DAQmx base.
http://www.youtube.com/watch?v=g_8jiKuKeDI
Warm regards
Mart G
Member
Bobino
Thank You for the video. It was very imformative. However, I still do not understnd why my program is not working. I made some small modification in order to share the Sample clock but this does not have anything to do with my problem, and in fact, it does not solve it.
Right now, I am wondering if the Start Trigger is done properly even though I have seen it done like this in examples online. Any comments would be appreciated.
Thank You very much
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
