I have a PCI-6224, SC-2345, 2 cables, 2 SCC-SG01 quarterbrige strain gaue modules.
Win XP Max 3.1, Nidaq 3.0
I am using the first set of channels 0-15 , to read analog voltage data (connected thru SCB 68 to terminal 1 of PCI-6224). The SG01 modules are put in SC-2345 slot J1 and J2. I configured the SC-2345 thru Max. The SC-2345 is connected to the 6224 daq card thru terminal 2.
I used daq assistant to generate a typical vi to read strain gauges.
question,1
how does daq assistant know that the SC-2345 is connected to terminal 2 and not 1. that is , the analog strain gauge channels read are 16,24, 17,25, as opposed to 0,8, 1,9 ? Currently, it uses syntax like SCC1/Mod1/ai0 etc
question 2,
Instead of worrying about configuration and all of that, and SCC1/Mod1/ai0 and all of that, can I simply treat the SG modules as simply output modules, that is
configure all my analog input channels as NRSE (range -10 to +10 V)
then read my analog voltage data, read all the channels that I need, including the SG01 channels (as dev1/ai16,dev1/ai24,dev1/ai17,dev1,ai25
and, then for the SG voltage data, I divide by 100 (because the SG modules have a gain of 100)
then use the calculated (divided) voltage as input to a the "convert strain gauge reading.vi", and calculate the strain (assuming my input data is set properly ; excitation voltage, bridige configuration, etc...
