I should have given details. I am talking about NI PCI 6110 board. The max the board can run is 20MHz. There are Digital and Analog I/Os. Can I run one pin on X rate and the other on Y rare? I want to run Analog and Digital I/O with different speeds. I think I can achieve it by using PFI pins, but I am not sure. Could those be used as timing signals for Digital I/O?
And again, what is maximum Digital I/O speed that can be achieved on the board, which simultaneously samples analog inputs too. Any buffer problem (On-Board) or RAM problem?
Attempt to solve any of these Questions are appreciated.
