Multifunction DAQ
Software for cDAQ-9171 + 9219 module + TJE Pressure Sensor
Thanks for the help. I have an elaborate test set-up build around VBA and Excel, so I have to stick with VBA. I use NI Visa to talk with insturments, and it works great. I'll buy another pressure sensor that includes logging software, and I'll have VBA open the log file peridoically and copy pressure readings. I have found that this works with other instruments when there is no NI VIsa driver.
Message 11 of 17
(1,780 Views)
I found that other USB pressure transducers on the market don’t have the high temperature rating of the Honeywell/NI TJE transducer. So I’m back to trying to get this TJE transducer to work with DAQmx.
I found this function that should make things easier: DAQmxCreateAIPressureBridgeTwoPointLinChan.
However, when trying to use this function in VBA I get error message “Sub or Function Not Defined” where the top of the message box is labeled “Microsoft Visual Basics Applications”. It seems that this function is not supported in DAQmx. I upgraded to DAQmx v15.5 (the latest available), but that did not help.
When I highlight the function in the code and activate a list of available DAQmxCreateAI functions, DAQmxCreateAIPressureBridgeTwoPointLinChan is not listed as an option. It appears that there are no Bridge functions available for use with Visual Basic. Is there some way to get a full bridge working for a pressure transducer with another function in Visual Basic (VBA)?
Message 12 of 17
(1,770 Views)
Hi Dan747,
I set up an example in excel and I am seeing the same thing you are. The DAQmxCreateAIPressureBridgeTwoPointLinChan works in our supported C environment (LabWindows/CVI), but since VBA isn't one of the supported environments of our DAQmx C API there is probably something with the way that and other functions are written that can't be used in VBA. The only function that is available in VBA and would output pressure explicitly is the DAQmxCreateAIMicrophoneChan, but I don’t know that this would do what you need it to. I believe you will need to use either the DAQmxCreateAIVoltageChanWithExcit or DAQmxCreateAIVoltageChan functions depending on your set up. And then, due to the fact that this does not output reading in pressure units, implement some custom scaling to transition from Voltage to Pressure.
A Johnson
Message 13 of 17
(1,743 Views)
Thanks. I tried to use DAQmxErrChk DAQmxCreateAIVoltageChanWithExcit earlier (see March 15 post). While the function was recognized, the control parameters entered such as DAQmx_Val_FullBridge caused "Variable not defined" errors. Below I show how I added some dimensioning for parameters and now the errors are gone. But after adding the other code needed including DAQmxReadAnalogF64 to read the data, I only get back all zeros. NI Max gives actual pressure readings, so I’m not sure why I only get back zeroes from the code.
Option Explicit
Public DAQmx_Val_FullBridge As DAQmxBridgeConfiguration1
Public DAQmx_Val_Internal As DAQmxExcitationSource
Public DAQmx_Val_Volts As DAQmxVoltageUnits2
DAQmxErrChk DAQmxCreateAIVoltageChanWithExcit(taskHandle, "cDAQ1Mod1/ai0", "", DAQmx_Val_Cfg_Default, _
-100, 500, DAQmx_Val_Volts, DAQmx_Val_FullBridge, DAQmx_Val_Internal, 2.5, 1, "")
Message 14 of 17
(1,733 Views)
Still trying to get basic DAQmx functions to work in VBA. This link implies VBA should work:  https://decibel.ni.com/content/docs/DOC-19654
For the code below, function DAQmxCreateAIVoltageChan gets an error from the ErrorHandler with message: “Error: -200077 Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.” Any ideas on how to fix this?
Option Explicit
Public taskHandle As Long
Public taskIsRunning As Boolean
Public minVal As Double
Public maxVal As Double
Public DAQmx_Val_Cfg_Default As DAQmxInputTermCfg
Sub Macro_Read_Pressure_Sensor()
minVal = -60   ' In volts
maxVal = 60    ' In volts
On Error GoTo ErrorHandler
DAQmxErrChk DAQmxCreateTask("", taskHandle)   ' taskHandle is an output
taskIsRunning = True
 DAQmxErrChk DAQmxCreateAIVoltageChan(taskHandle, "cDAQ1Mod1/ai0", "", _
     DAQmx_Val_Cfg_Default, minVal, maxVal, DAQmx_Val_Volts, "")
‘ Other DAQmx functions here …
StopTask
Exit Sub
Message 15 of 17
(1,666 Views)
I tried out your code on my own and I didn’t receive that same error. However, there was another error with that function call related to syntax. You should make sure there is no underscore before DAQmx_Val_Cfg_Default. I don’t know if that was a typo while making the forum post or if it’s a typo in the code. Either, make sure it is removed.
Was there any more information that was provided with that error message? Often if a property is mentioned there will be a listing of the property name and the expected value type.
Message 16 of 17
(1,648 Views)
The underscore means the code is continued on the next line in VB.
After more attempts I was able to read a voltage using the code below. The parameter "DAQmx_Val_VoltageUnits1_Volts" is not documneted on the NI webpage for the  DAQmxCreateAIVoltageChan function. I found it elsewhere, but it seems to work.
Next I'll try to read a thermocouple and then finally the pressure transducer.
Option Explicit
Public value As Double
DAQmx_Val_Cfg_Default, minVal, maxVal, DAQmx_Val_VoltageUnits1_Volts, "")
DAQmxErrChk DAQmxReadAnalogScalarF64(taskHandle, 10#, value, ByVal 0&)
ActiveCell.Activate
ActiveCell.offset(1, 0).Range("A1").Select
ActiveCell.FormulaR1C1 = value     ' is written to Excel cell
StopTask
Exit Sub
Message 17 of 17
(1,642 Views)
