Petteri,
I don't have the hardware to reproduce this, but I have a few ideas. For analog output, are you creating a task, starting it, and calling write repeatedly, or are you simply calling write? While an AO Task will auto start on write, it will also go through the process of stopping when the write is complete. Which means next time you call write, the task will need to start again. It will be much more effecient if you explicitly call start on the task once, perform as many writes as required, and stop/clear the task when you are done. This same principle applies to you analog input reads as well.
I hope this helps,
Dan
