Multifunction DAQ
Simultaneously read more than one input and generate output
Is it possible To simultaneously read more than one input and generate outputs depending on these inputs? If this isn't possible what is the best way to go about making some sort of timed loop that will read an input, read the next input, decide whether or not to output and so on. Hope someone can help. Thanks.
Message Edited by Esmith13 on 05-25-2005 01:36 PM
(2,535 Views)
You should look at the synchronized examples for analog input and output that can be found in the example finder under:
Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Synchronization>>Multi-Function
These will get you started to being able to handle multiple tasks at the same time.
I hope this helps. Have a Great Day!
George
(2,515 Views)
