NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
CHersh
SignalExpress freezing at stop of log, USB6008
Hi everyone,
I am wanting to use my NI USB-6008 DAQ to take a voltage data point on four channels once every 10 minutes for a few days at a time.  I have changed the timeout to -1 seconds and turned off automatic exporting of log file.  I am also using the save to ASCII step.  When I go to stop the run, it hangs up.  My computer is pretty bad, but I can do the same operation with a much faster sample rate no problem.  Does the 6008 have a lower limit to sampling rate?  I just started messing with this program yesterday so I'm still learning.
Chris
Member
CHersh
Re: SignalExpress freezing at stop of log, USB6008
I tried using my laptop (which is much faster than the desktop I'm using) and I got the same problem.  Any suggestions?
Member
CHersh
So I did some more searching through the expansive knowledge base and found that the minimum sample rate for the USB 6008 is 5.587935 mHz (source).
I ditched the save to ASCII step for now, and have gotten the program to collect some data at 10 mHz, currently trying it at 6 mHz now.
The main cause to my problem so far has been with what seems to be an error with the continuous data collection option.  I discovered that eventhough the sample size is supposed to be treated as buffer size in this mode, for me it was not.  I would set it to 20k 'buffer' at something like 1 kHz samples and it would 'freeze' on stop.  I let it go like this for a while once and to my suprise it came out of it and I was able to view the log.  When I did I saw that the log went to exactly 20k samples, eventhough I had stopped it within ~5 seconds.  So during that time it was 'stopping' it was actually finishing the program and getting 20k samples.  This is why I always had a problem trying to record at low sample rates with what I thought was a 1k buffer - but was actually 1k samples.
So..... why is this happening?  I want to actually collect continuously, but also stop it whenver I want (eg. continuous up until I stop it).  I might try the 'n-sample' mode now, considering the rest of the problems with this program, they could very well be flipped.
Assuming I figure out how to get it into true continous mode, will I be able to stop the logging at my will?  And what should I set the buffer to with a sample rate of 6 mHz?
Chris
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
