Please allow me to further clarify. When in multiplexed mode, meaning the analog channels entering each SCXI module are multiplexed through the SCXI backplane, the limits are 333 kS/s for 12-bit accuracy and 100 kS/s for 16-bit accuracy. Even in the multiplexed case, you can scan faster than the rates above, but you will your signal will not settle properly.
In parallel mode, the rates above are useless because the signals are not being routed through the multiplexed SCXI backplane. In the parallel mode case, each signal is sent, in parallel, through its own circuitry and is fed directly to the data acquisition device. When this happens, the settling time constraints are moved from the SCXI multiplexing backplane to the data acquisition device itself. For instance, if I am using a data acquisition device that is capable of 1 MSample/s, and I am using it in parallel mode, I can use the DAQ device, and the accompanying SCXI module, up to its full sampling rate (1 MS/s). Whereas, if I was using SCXI in multiplexed mode, I would be limited to 100kS/s or 333 kS/s, depending on the resolution of my daq device.
Whether you are multiplexing through the SCXI backplane or on the DAQ device itself, there are selling time restrictions and the analog to digital converter is shared amongst multiple channels. S Series devices offer an advantage over multiplexed data acquisition devices since they have an ADC (analog to digital converter) per channel. This is significant since the sample rate is not divided by the number of channels scanned and you get simultaenous sampling of all incoming signals.
When placing an SCXI module that is parallel-mode capable; such as the 1125, 1141, 1142, 1143 and 1520; in parallel with an S Series device, the bandwidth/scanning limit is typically the bandwidth of the SCXI device, not the scan rate of the DAQ device. For instance, if I use the 6133 (2.5 MS/s per channel) in parallel mode with the SCXI-1125 (maximum bandwidth of 10 kHz), I will be able to oversample the maximum frequency content of the signal by 250X. This is a bit of overkill.
When using the SCXI-1125 in parallel mode with S Series, I would suggest using the NI 6143. It is capable of 250 kS/s per channel and has the appropriate amount of resolution, 16-bits. Using the SCXI-1125 and NI 6143, the maximum frequency content of the signal will be oversampled by 25X. The 6143 is lower cost than the 6133 and offers better matched performance to SCXI parallel-mode capable modules.
Again, this capability is not availible until the release of NI-DAQmx 7.4 which will be availible on the web sometime next week. I hope that this clears it up for everyone.
Brent
