Multifunction DAQ
Sending boolean array trough DAQmx digital output
I'm trying to send the 3 boolean array trough 3 line of my DAQmx usb 6002. But i see nothing an their is no error shown. What is wrong with the graph i did ?
(2,700 Views)
You must to build a array of the three arrays using buld array function. After this one must be wired to the data input of daqmx write function.
In addition:
http://web.mst.edu/~cottrell/ME240/Code-hints/Dice.htm
http://forums.ni.com/t5/Example-Program-Drafts/Write-to-Multiple-Digital-Channels-with-a-Single-DAQm...
Best regards
(2,625 Views)
