Multifunction DAQ
Sending a byte to a digital output using a VI
Ok, well speed is not a concern here, but the MCP configuration is synchronized on the clock and the data array should always be a multiple of 16, for 16 clock rising edge. That is why i was worried about having two output working at the same time.
I'm trying to implement the graph shown above and i would like to know something...
Can i simulate a byte array with a signal generator or something, whitout using a real entry on my 6002, and if so, how can i see the signal flowing trough the graph ? On the front panel, the number put into the "U8" Array should be in decimal ?
Message 11 of 11
(764 Views)
