Multifunction DAQ
Reply
SMU vs. DAQ
SMU vs. DAQ
Hello to everyone,
thanks in advance for all you can suggest to me.
I am wondering about the purchase of 2 SMUs vs. DAQ.
What is the real advantages of using a SMU instead of a multifunction data acquisition ?
(I have seen for example the NI X series Multifunction data acquisition systems).
G.
(305 Views)
Re: SMU vs. DAQ
They are two completely different types of equipment.  An SMU is a Source Measuring Unit.  You can think of it as a very precise power supply.  A DAQ is a Data Acquisition.  It only reads voltage, usually in many channels at a time.
So the real question is what are you trying to do?
The discussions from the Advanced User Track is not over. Join in the conversation: 2016 Advanced Users Track
(298 Views)
Re: SMU vs. DAQ
Hi
(265 Views)
Accepted by topic author pogor
03-14-2017 02:07 AM
Re: SMU vs. DAQ
The problem you might have with the analog outputs of a DAQ is that they have a really small current limit.  I would use 2 SMUs for my input and a DMM to measure the output.  I am sure you can find an SMU with a lot lower voltage range.  Just a quick look and I see a PXIe-4144, which has 4 outputs at 6V, 500mA.  So I would go with that and a PXIe-4081 DMM.
(260 Views)
Re: SMU vs. DAQ
Hi again Crossrulz, and thanks for the suggestion, that looks very very great...
It seems a very good solution...
G.
(235 Views)
