08-10-2015 03:34 AM
Good day,
i'm not able to change or select the proper/new Daq device to be connected to our "old" SCXI chassis.
see attachement.
I want to select Dev2 (usb 6361 daq) to be the chassis communicator. It doesn't appear in the drop down list. Only the simulated DMM (4065) appears ?????
regards,
Koen.
08-11-2015 08:39 AM
Hi Koen,
My name is Joshua Young and I am from the Applications Engineering department at National Instruments UK.
Just to clarify some details, you have a SCXP 1001 chassis and want to use an NI USB-6361 as a chassis communicator in order to acquire data. When setting up in NI MAX you are unable to select the device in the drop down menu.
I have looked into the compatibility of the SCXI 1001 and X series cards. Unfortunately, the USB-6361 is not able to be used as a communicator with your chassis, hence why you cannot see it in the drop down menu. It only seems to be the USB-62XX devices from the USB range that are compatible with the SCXI-1001.
If you would like any more information on possible hardware solutions I would gladly help.
Kind regards,
Joshua Young
08-12-2015 11:07 AM - edited 08-12-2015 11:12 AM
Actually, support for SCXI over USB was added with the release of mass termination USB-62XX devices, but it's not exclusive to that group of products anymore. The USB-6361 that Koen is using can be used as a chassis communicator.
Koen,
It looks like your system is not properly recognizing the 6361 as a Data Acquisition Device. What happens if you try to self-test it in MAX? What does it look like in Windows Device Manager?
08-17-2015 10:27 AM
Good day,
the selftest succeeded ok & in the device manager usb6361 is seen as NI DAQ working properly.
Though not selectable/viewable in drop down for chassis communicator.
regards,
Koen.
09-24-2015 05:31 AM
I now inserted a PCI 6221 NI card and I also can not select this card as chassis communicator.
