I am using a SCB68 and the AI0 is giving corrupted data. Instead of reading a 0N signal from a force transducer, I get 175N. And the signal does not change when applying force (It works fine apart from the noise with the other AI channels). I want to be sure that this corrupted channel is not affecting the others. Is there a way to silence a channel?
