Multifunction DAQ
SCB-68 Reference Label for M series devices
What's the difference between the SCB-68 Reference Label M series devices connector 0 and connector 1? I'm installing a NI PCI-6221-M series Multifunction DAQ and the SCB-68 connector block, and I don't know how to make the physical connections. With the SCB-68 kit, I received the Reference Label for the E-series devices. In the NI site, there is info about the connector 0, but what is the connector 0 and connector 1?
ZeK
(2,706 Views)
Good question Zek. The M series family uses a smaller version of the 68-pin connector used on E series so that two connectors can be located on the same board. The second connector is available on certain M seriies boards in order to provide connectivity to additional channels. In the case of the 6221, there is only one connector.
The 6221 is fully compatible with the SCB-68. The following link provides a revised version of the SCB-68 label adapted for M Series devices:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/61ed77983ad7cca386256f66008215f1/$FILE/SCB68%20M%20Series%20Connector%200.pdf
For pinout specific to a particular M Series device, you can refer to the M series help available at either one of the following locations:
http://digital.ni.com/manuals.nsf/websearch/9477D6DF1FE5A72986256FAB00633DE4?OpenDocument&node=132100_US
http://digital.ni.com/manuals.nsf/websearch/3AE9D4533E03A6EF86256FE300809FE6 (HTML format)
(2,697 Views)
