Multifunction DAQ
SCB-68 Pin#8 (+5V) not working
I am using PCIe-6321 DAQ and SCB-68 connector block to connect two stepper motor drivers and drive the stepper motors. I need to provide +5 volts to my driver in order to power the emitter diode in the opto-isolators in the drivers. I am able to get +5 volts from pin 14 of the SCB-68 but I am unable to get the +5 volts from the SCB-68. The Quick Reference Lable states the pin 8 as +5V, Fused. Can anyone suggest me what I am supposed to do in order to obtain the +5 volts from pin 8 of the SCB-68.
Bharath J S
(4,805 Views)
So you can read 5V from pin 14, just not pin 8?  You may have a blown fuse on your DAQ board.  I'm not sure if there are seperate fuses for each output.
(4,803 Views)
Yes I can read 5V from pin 14 but not pin 8. If the fuse is blown on the board, is it possible to change it.
(4,789 Views)
According to the data sheet, it's a self-resetting fuse. Have you checked pin 8 at the DAQ card itself?
(4,773 Views)
